First post, by dosquest
So I have my copy of Harvester and I have been playing it on my DOS machine, and I'm wondering, I've cleaned and serviced my CD-ROM drive so I don't think any wild plastic spurs or sharp edges on my cd tray will gnaw at it, yet I'm worried that with such a rare FMV game can actually playing it damage the discs?
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 1 of 13, by bjt
Just make backup copies and play from those (now explicitly allowed by law in the UK).
Reply 2 of 13, by Harekiet
Rank DOSBox Author
DOSBox Author
I'd rather just play it from virtual cd's instead of having to hear that evil cdrom spinning noise 😀
Reply 3 of 13, by dosquest
I'm not using Dosbox. I'm using physical hardware, circa 1996
Reply 4 of 13, by leileilol
Lack of care for CD-ROM drives will damage discs. Games do not discriminate this behavior.
that said, the day my CDs stopped scratching so much is the day I stopped using MITSUMI CD-ROM drives
Debian's fucked
Reply 5 of 13, by ElectricMonk
Depending on your drive, there's always a risk of scratching the disks. I had a high-speed plextor drive that tore up discs like nobody's business. Imaging the discs, and running them in some type of virtual drive is the way to go.
Besides, CD-ROMs are notorious for "cd-rot" as they get older. They're gonna fail eventually, so go ahead and image them now, while they're still readable.
Reply 6 of 13, by jwt27
That's no reason not to use disc images (unless the game uses CD-audio music)
Reply 8 of 13, by King_Corduroy
I usually Image the disk in question and burn myself a "beater copy". I do that for all my games and it works perfectly even if the disc needs to be accessed for audio or video since it is an exact copy of the original.
The only one I cannot seem to make an image of is Omikron : The Nomad Soul. It simply will not recognize it and create and image. 😒
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 9 of 13, by JayCeeBee64
Rank Retired
Retired
I don't own this game, but I know it's copy-protected with SafeDisc (Midtown Madness 2 and MDK 2 have the same kind of protection). Try using Alcohol 120% or CloneCD; the copy may still not work, though.
Ooohh, the pain......
Reply 11 of 13, by dosquest
Im pretty sure ms-dos 6.22 can't load image files. As for making copies I'll try that.
Reply 12 of 13, by Harekiet
Rank DOSBox Author
DOSBox Author
Freedos has a cdrom driver that can mount an iso image under dos. Swapping cd's might be troublesome but then again maybe harvester just has some functionality to use a harddrive directory where you copied the cd contets to.
Reply 13 of 13, by dosquest
I tried the no cd method I figured out for dos of, it crashes when starting a new game 🙁 so there must be sme work wound that was added do dos of, because it has so much compatibility, which my plain Jane dos system doesn't have.
