First post, by wemelchor
hello yes i want to play doom using this tutorial
http://forum.xda-developers.com/showpost.php? … 371&postcount=3
and the first thing I realize is that it sucks and doesn't work! I've had little sleep over this and I want it solved.
when I type "\cd dos" it gives me the same bloody error message!
unable to change to: dos
am I annoying you yet? yes this infuriates me as well. for a 4$ product I am angered by the fact that I can't even to the most basic of tasks without this crap.
Reply 1 of 6, by DosFreak
We have nothing to do with DOSBox turbo.
We support DosBox for the PC which is free.
The error you're receiving is telling you that it cannot find the "DOS" folder. So either tell it to use another folder or create the folder.
Make your games work offline
Reply 2 of 6, by wemelchor
thank you for the reply. I think turbo is broken because it cannot find any folder. it is essentially blind
Reply 3 of 6, by DosFreak
Does Turbo require you to mount folders?
If so then you'll need to perform a mount
Mount c c:\dosbox
C:
cd dos
The above assumes DOSBox for the PC.
I don't know anything about how Turbo does it.
Reply 4 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
The instructions are just incomplete, I'm sure Dosbox Turbo can nicely run Doom if the mountings are done properly...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 6, by SKARDAVNELNATE
You have the slash in the wrong place.
Reply 6 of 6, by King_Corduroy
Well you don't really need the slash in there at all unless you are giving the full path.
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
