Reply 40 of 68, by squareguy
- Oldbie
I believe i found a solution. Cannot disable ACPI in BIOS which would be nice. I got to thinking about the age of the computer and surely someone wanted to run 98 on this thing when it was new and sure enough there was. Basically it's because Windows 98's ACPI implementation sucks balls. What? What's wrong with golf balls? I mean it's not like I said... Anyway I just need to instal Windows 98 SE with this command "setup.exe /p i" which tells setup there is no PnP BIOS. I should have time tomorrow to do this.
EDIT: pewpewpew, I looked at the SP3 but I did not see anything dealing with ACPI
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
