First post, by ahendricks18
Well what I thought would be 2 old PC's turned out to be just two broken CRT monitors. The one Nokia monitor turns on, but snaps if you leave it on. They both were wet. Can I fix this somehow? Probably not, but whatever.
Main: AMD FX 6300 six core 3.5ghz (OC 4ghz)
16gb DDR3, Nvidia Geforce GT740 4gb Gfx card, running Win7 Ultimate x64
Linux: AMD Athlon 64 4000+, 1.5GB DDR, Nvidia Quadro FX1700 running Debian Jessie 8.4.0
Reply 1 of 14, by Harekiet
Rank DOSBox Author
DOSBox Author
I wouldn't exactly wanna risk a high voltage jolt from a crt 😀
Reply 2 of 14, by ahendricks18
Yeah, I heard if you touch the thing inside it could kill you. I guess I'll let it dry and if it doesn't work, it's off to the dump with them.
Reply 3 of 14, by leileilol
I would just give up and dump them at that point. Retro computing isn't something you'll chance your life on
FUCK "AI"
Reply 4 of 14, by jwt27
The HV is not too lethal. The big caps on the power supply board are. Make sure to discharge them and you should be fine.
Reply 6 of 14, by 133MHz
Remove the plastic casing and leave them out under the sun to dry out for a few days.
http://133FSB.wordpress.com
Reply 7 of 14, by Gemini000
Maybe stick 'em near a dehumidifier for a good chunk of time? *shrugs*
But yeah, don't screw with high-voltage stuff if you don't intrinsically know what you're doing. CRTs are the second-most dangerous consumer-grade electronic device to work on, followed only by microwave ovens. :P
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
Reply 8 of 14, by obobskivich
I'd say off to recycle with them and find a new monitor somewhere else - like collector says, there's an ocean of them available used.
Reply 9 of 14, by Sutekh94
I'd agree with dumping them. You'd probably be better off going to the nearest thrift store/Goodwill and buying one instead of trying to fix those broken CRTs.
My YouTube | My DeviantArt
Reply 10 of 14, by 133MHz
No love for them CRT displays around here I see. 🙁
Reply 11 of 14, by pewpewpew
Well... none for wet soggy CRT that are so easily replaced by better. Nope, none.
I ought to add that if he's just 'south of Buffalo' then he's just entering real-snow-country Winter -- it's not going to be good drying weather where he is for several months. Sometimes it's best to punt. This is that time.
Reply 12 of 14, by PeterLI
Goodwill and Best Buy take them for free: no questions asked. 😀
Vintage computer stuff is very common upstate so you can pick up lots for cheap anyway so why bother with drying / repairing and so on.
Reply 13 of 14, by cdoublejj
let it dry naterualy. that is your only option if you don't want to take it apart and clean it.
Reply 14 of 14, by ahendricks18
Yeah, i just dumped em both today, but i got a packard bell in its place!
