First post, by meljor
Hello there...
Has anyone here ever tested if there is a performance difference when it comes to chipsets paired with a cyrix cpu?
I'm planning on building a pc with a pr233 cpu (2,5x 75mhz or 187mhz) and i have a few options when it comes to picking a board for it. For example, i know the Intel hx chipset is among the fastest for intel cpu's but is this the same for cyrix? I don't have a hx board but here are my options:
Dell board with intel VX
Soyo sy-5vd intel VX
Pc partner intel VX
A-trend 5030 with intel TX
Asus p5a Ali V
Msi 5169 Ali V
Jetway J-542B Ali V
Jetway J-542C Ali-V
Aopen ax59pro Via mvp3
chaintech 5agm2 Via mvp3
The Dell board i use for my mmx system and i know it works great (the mmx can move to another board if needed).
I tested fully my Asus p5a boards so i know they work (my favorite for my k6 cpu's, but i have spare boards)
The Aopen is my favorite Via board and i know it is also 100%
The rest i never used but i know they post so i think they are ok, and some came out of working systems.
So, assuming they all work, what is the best pick for my upcoming cyrix build? I want max. performance from it since it has to power a voodoo1 board. Or is a Voodoo rush a better match for this system? Or overclock the Cyrix?
I have other systems for heavier games but it would be nice to be able to play all voodoo graphics games on this system. It will also be used for dos games and i wonder which vga card i should use since i have a few options here also.
Summary of questions:
Which chipset or better, which board from my list for the cyrix.
Voodoo1 or Rush
Good stable overclock settings for the cpu (not over the top)
Which card: S3 Trio 64V+ 2mb, Riva 128 4mb, matrox g200 8mb pci, S3 Virge 2mb , S3 6326 4mb or S3 virge/dx 4mb (if paired with voodoo1, otherwise i use the 2d of the Rush ofcourse)
I prefer ATX boards for my systems but for this one i can make an exception and go AT, it all depends on which board you guys recommend.....
It will be paired with 64mb ram (edo or sdram) and an AWE32 isa card.
