Reply 40 of 53, by HighTreason
- Oldbie
As I said, I don't rate gaming hardware and rarely go near it if I can help it, there has to be a reason that it costs the same as a good workstation board but they somehow managed to get all this extra plastic all over the place... Makes you think the plastic is 90% the cost instead of a well thought out design... Also RoHS sucks.
I tried overclocking the Pentium to see how fast it would go, 215MHz on the FSB proved to be the limit which yielded around 3GHz but that was literally just a few minutes, I don't overclock machines that are used for anything important and even then, I rarely do it for ones that aren't.
As I said, the 754 versions of the 64 seemed to be better, I never attempted to use one as a performance machine so I don't know how they fare at that and I doubt it was their intended purpose so it probably wouldn't be a fair test, but as a generic desktop they worked well - I even have an Athlon 64 3200+ on some ECS board I bought as a cheap bundle years ago that I use as a testbed. It's lived a horrible life and still just plods along happily. I didn't expect much from it, so overall I'm happy with that one.
Core 2 Quad is the newest thing I have, I had hoped the Pentium could hold on until I got a replacement set up, but it didn't and the replacement is getting no nearer to being affordable. I'm thinking of giving it one last go once I'm done playing with film and maybe getting another synth, but if I can't scrape the money together in a few months I'll probably just get a last-gen i5 and make do with it, the performance boost should be ridiculous anyway I would have thought.
