First post, by thegreatholdini
Hi
I have successfully managed to run an old DOS program in DOSBOX.
The program communicates with a remote PC via a 56km dial up modem. USRobotics USR5630G 56K* V.92 Serial Controller Faxmodem (RS232)
http://www.usr-emea.com/support/s-prod-templa … emea&prod=5630g
Whilst I can use the modem on Windows 7, at the moment I cannot detect the dial up modem within DOSBOX. I have tried the following:
http://www.dosbox.com/wiki/Configuration:SerialPort
The modem is connected to the PC via the single Communications Port (COM1). I have thusfar tried this command:
Z:\> serial1=modem listenport:com1
I then try to use the dial up modem from within the program but nothing occurs....... Any help would be greatly appreciated
