PeterLI wrote:When you regularly check eBay / Marktplaats / Tweakers and so on I am confident there will be an IBM 51** case for cheap sometime. There are even more in the US (obviously).
Looking there is always a hard job to do.. Yes i regular check those sites too.. But i actually dont find the things there iam looking for sadly.
And then an IBM enclosure isnt not the case iam looking for.. It just needs to be a clone computer instead. ( the case i have here is just one of the original ST-JUKO motherboard cases..)
Logistics wrote:Let me get on thing out of the way: does the case still have feet? I just want to know if the bottom surface will actually touc […]
Let me get on thing out of the way: does the case still have feet? I just want to know if the bottom surface will actually touch anything because if not, you can get away with low-grade coatings like enamel.
I'm mainly an automotive painter, but I spent years working as an industrial painter so I've become familiar with industrial coatings as well. And whatever is on old computer cases always struck me as polyurethane because its tough! BUT because I never see a primer-coat underneath the paint, I get the feeling cases are powdercoated.
Ah, I apologize; I keep neglecting the fact that you're talking about the chassis. The chassis are painted a matte black, and they don't have a primer-coat under them, normally either but they also don't have to endure any action like the cover does. A matte-black enamel should be fine.
As far as prep is concerned, I would suggest starting with something like 120-grit to get rid of the scratches, then using 240 to smooth things out. Use several light to medium coats. Don't use heavy coats. And read the directions to find how long the paint should flash between coats.
There where feets underneath this case.. I see this because there was sticky stuff on it, that i removed it some days ago. From an other AT case i bought new then (on my opinion to cheap quality) I have some set new feets over from that case iam can use for it.. I see also the blanc metal of the case, so yes there is no primer-coat used.. Otherwise i would see no rust spots on the metal.
I guess enamel isnt just a paint? So the case needs to get in to an oven?
Iam think i leave the original paint as possible on the case.(For better adhesion) Then sanding it with a fine sandpaper (specially for paintings)
And then will look for paint that best matches the case cooler.. First trying to fill the places where the paint is of the case.. Then give it a good dry..
Then again i would sand it again so everything would smooth again.. And then with a roller i would repaint to whole bottom.. I dont think a spray can would be a good idea..
1. Iam not very skilled to use spray cans, because iam to impatient. ( using spray cans you need to learn it first by doing it a lot of times)
2. I also dont want to cover the rest of the better parts with paint spray. Because the spray is going every where.. (i know i need to cover up the other case parts, but dont want to damaged it because of stickers er tape residu or be affraid pulling of the standard paint when removing the tape.. Also it would took a lot of time to cover all of these good parts.
3. I think the quality with a good quality paint roller would be definitely be better if you just roll with fine layers of paint on the case bottom.
But before going to paint mindless, it would be a great idea to test some paint first to match the right black..
Does enamel paint always have from those `spots`in the paint:
I think its almost the same my case have.
