First post, by Supra107
Hi, i use DOSBox for Windows 3.11, because sometimes i want to run a old 16 bit Windows game on a 64 bit system.
And the problem is: I don't know what optimal config of CPU, SB and others to set in dosbox.conf.
Reply 2 of 3, by Supra107
Well, optimal in the way that it will have good CPU cycles for using it and good audio settings, because i got farts and snaps when i'm using it.
Reply 3 of 3, by Quadko
I've had pretty good luck using the default settings, but I'm not running any really challenging games, and I'm not sure I've ever set up the sound all the way... I forget.
So, which game(s) are you having trouble with? Or is it just in win 3.11 sound playback itself having trouble?
