VDM sound and emulators?
First post, by ade
I'm wondering whether VDM sound will run with any emulators?
I've got one called T3 which runs old Dragon 32 games but theres the sound doesnt work. The read me suggests I need to set the sound blaster however as I'm running Windows XP I dont have a sound blaster so figured I could use VDMSound to emulate it.
But I dont know if I can. Anyone help or advise how I can set it up so I can run it in line with an emulator?
Ade
Reply 1 of 2, by Iron
Well, if it's a dos program like it sounds it should run with vdmsound if it runs with novoice without vdmsound. Ofcourse looking for a windows version would be a good choice but if there isn't one it's worth the shot. just try it. check that the vdmsound settings match with that program's settings.
Well now I checked their page and see that it's designed for a 386 computer. So I think using dosbox is a great choice too. Should run fine there.
I think if it runs fine on windows without sounds it should run ok with sound if you use vdmsound. Good luck 😀
Reply 2 of 2, by ade
thanks.
I went into the program (t3-100), right clicked and loaded using VDMS - loaded fine.
However still no sound. I'm not 100% sure if I'm doing it right though
Any chance of a step by step?
(sorry)
(ps - I've read the step by step in the beginners section - didnt help unfortunately)
Ade
