IBM 5151 monitor repair
First post, by jwt27
My IBM 5151 did some funky things recently, so I thought I'd replace the capacitors first, see if it helps. All the electrolytic caps are the infamous TEAPO brand... and seeing as these are at least 30 years and 2 months old now, I'm quite surprised this thing still even works (somewhat).
I wrote down all the values, but noticed two unusual caps. First, one of the largest caps, C505, is labeled 18µF/25V. I think this is way too small for such a large cap! 180µ/250V or something would seem more appropriate. C602 for example, which is about the same size, is labeled 4700µF/35V. Also this C602, is one of those three-legged freaks. Not sure what to replace it with.
Here's a list of all the electrolytics inside. Could anyone confirm these numbers for me? (or at least C505)
num     C(µF)   U(V)    d(mm)   h(mm)   p(mm)
C202 47 10 5 11 5
C204 1 50 5 11 5
C205 2200 16 10 12 5
C405 10 16 5 12 5
C408 2200 10 16 26 7.5
C409 1000 25 16 25 7.5
C410 100 25 8 11.5 5
C502 1 50 5 11 5
C505 18 25 22 41 10
C506 220 25 10.5 17.5 5
C514 47 63 10 12 5
C602 4700 35 25.5 40 12.5?
C604 4.7 50 5 11 5
C605 4.7 50 5 11 5
C? 100 100 13 20 5
To open it, you'll first have to pull out the contrast/brightness knobs. Lift out the two small covers on top with a screwdriver and remove the screws underneath. Then put it face-down on the table, and remove these screws on the underside: http://www.minuszerodegrees.net/5151/misc/5151_underside.jpg
Then disconnect the black ground plug from the circuit board, and remove the two screws that hold the contrast/brightness pots to the front bezel. Now you should be able to pull the circuit board out.
About safety: I left mine unplugged for two days and didn't find any dangerous charges. In fact, I didn't find any charges at all, not even on the tube itself. So if you just pulled yours from the attic, it should definitely be safe to open.
Reply 1 of 11, by 133MHz
According to this Sam's Computerfact for the IBM 5151 C505 is a non-polar capacitor hooked up in series with the horizontal deflection coils, which means that large currents pass through it and therefore it must be a beefy low-ESR part (a common electrolytic would blow up nicely in its place). I'd recommend replacing it with four 4.7µF 50V+ ceramic capacitors in parallel for lower total ESR and increased reliability compared to electrolytics.
http://133FSB.wordpress.com
Reply 2 of 11, by smeezekitty
Or two beefy 10uf poly-film caps likes these: http://www.digikey.com/product-detail/en/ECQ- … EF1106-ND/56416
Its worth the extra expense. High ripple and non-polarization is not exactly electrolytic's strong suit
Reply 3 of 11, by jwt27
133MHz wrote:
THANK YOU! I've seen this manual referenced in serveral places but couldn't find it anywhere myself. This is really helpful.
I did notice it was a non-polar cap yesterday after writing that post, but didn't see it's connected to the horizontal deflection. Using an extra-low resistance part would make sense here! This would also make it prime suspect, since a "narrow" picture was the main problem I had.
How about using four of these? Or 2x5.6 + 1x6.8. I used the same types in my speaker crossovers too 🤣
I also noticed something else: the flyback is a bit "leaky". The clamp that holds the ferrite core together is corroded, and it looks like it arced over into the dust from there:
Let hope this doesn''t cause any trouble...
Reply 4 of 11, by smeezekitty
Those will be great.
That is concerning. But if you are still getting raster, it is likely still okay.
"Narrow"? How narrow?
Reply 5 of 11, by jwt27
I think I'll patch it up with silicone grease for now, and first see if changing the caps has any effect. If I can fix it without changing the flyback, I think I'll still hunt down a spare one, just in case.
It only fills about 3/4 of the screen now. Vertical is still good.
This all started when suddenly the screen size and brightness increased very quickly (in less than a second). Then I got a short, very bright green flash from the entire screen, and the horizontal width and position started changing randomly and very rapidly. After a minute or two it settled down slowly and now it's stuck at about 3/4 of the total width. Now the brightness also won't turn up as far as it used to, normally there would be a point where the entire raster is illuminated but it won't even go that far anymore.
About an hour later the picture started jumping around all over the screen (without changing in size), this lasted for about 10 minutes and eventually it settled in the middle again. I've used it for several days afterward without any weird things happening, but the narrow picture and low brightness remains.
Reply 6 of 11, by jwt27
Received a box with electronics parts today, including caps. Possibly the most overkill types you can imagine. Now I just finished soldering them in.
This is how the large non-polar cap ended up, I think it's the neatest looking way I could get all these film caps to fit:
Of course, the question still remains... did we incidentally fix anything?
The answer is: no. Nothing changed, it's still narrow and rather dim, same as before:
So with that, I can conclude my little experiment: "30 year-old Taiwanese-made electrolytic capacitors should never be trusted?" --> I'd say, MYTH BUSTED! 😀
Now I can start trying to repair this thing. The width and brightness offsets are probably minor enough to correct with the internal control pots, but then that wouldn't really fix anything, would it? And these pots don't turn themselves, so something else in there must have failed. I think I'll start following the SAMS manual and see if I can find anything unusual. Any other suggestions on what may have failed would be very welcome, too!
Reply 7 of 11, by 133MHz
Check if the B+ voltage is within spec, when it gets low you usually get a narrower, dimmer raster.
Reply 8 of 11, by jwt27
Yep, that's it! It's down to 11.6V (should be 14.9V)
When I desolder everything from the B+ rail it's still 11.6, so no shorts. Resistors and diode stuff seems good, and I tried replacing the big transistor with a new MJ15004 I found in my parts pile. Still 11.6. So the only remaining option is that the 7815 just.. "upgraded" itself to a 7812.
Do you think this could have affected both horizontal and vertical deflection separately? The weird part is that it did two different things spaced about an hour or two apart. I would expect to find at least two failed parts.
Reply 9 of 11, by 133MHz
I'd replace C603 and C409 just in case. The regulation stage is so simple that there's very little that can fail, and using the shotgun approach might be quicker than actual troubleshooting.
As for your second question, both the horizontal and vertical stages are powered from the main B+ rail so it's likely that it was a cascading failure - some component fails in a particular stage putting additional stress on the stage behind it, which then fails, propagating backwards - much like the massive blackouts we've been seeing around the world in the last few years, which are usually caused by a small overload causing a chain reaction.
Reply 10 of 11, by jwt27
Yeah I've replaced all the electrolytics already, and will leave them in. I think it'll be good as new again with a new 7815, but I'll have to order one first since I don't think I have any of these on hand.
Would make sense, but then vertical didn't actually fail completely... It fixed itself about 10 minutes later...
Reply 11 of 11, by jwt27
Got some new toys from China 😀
That's the big non-polar 18µ cap from the horizontal drive circuit. No idea how accurate these meters are, but both say all the caps I pulled from this monitor are as good as new... 🤣
