SIS 85C496 VS UMC 8881
First post, by Stojke
I have one motherboard (MB-8433UUD) that has an dead Odin (burn in hell) battery that i cant replace easily. It utilises UMC88881 chipset and AMD 5x86 works at 160MHz (as far as i managed to test). It has an PS/2 port.
But i found an cheap motherboard with Coin cell battery, PS/2 header, 2 PCI ports, EDO RAM, but SIS 85C496 chipset.
Should i replace the MB-8433UUD with the other one?
Reply 1 of 7, by smeezekitty
I say go for it. I love the coin cell and the 496 chipset rocks.
Reply 2 of 7, by dirkmirk
UMC is a faster chipset from my testing, you can run a voodoo card in the sis if you want to mess around with that sort of thing, personally I'd go for the UMC as I have an adapter that can run PS2 mice/keyboards and 3D cards aren't practical for this kind of CPU anyway.
Reply 3 of 7, by devius
Like a ISA card with PS/2 ports or just a regular DIN -> PS/2 adapter?
Reply 4 of 7, by Stojke
Probably that dual PS/2 cable with active circuitry.
I understand UMC is a good chipset, but replacing the battery is a huge pain, i dont have the proper tools.
Reply 5 of 7, by devius
I have a board based on a 85C496 chipset (Chaintech 486SPM) and although I only used it briefly for testing it handled everything I threw at it (I didn't had a 5x86 at the time though). The coin cell battery is definitely an advantage, and if it has a PS/2 port even better.
Even if the UMC board is faster I doubt you'll notice any difference. However, I haven't done any comparison tests between those two chipsets. Someone else may have more information.
Reply 6 of 7, by JaNoZ
What do you mean, you can buy a new RTC and replace it, or is there no RTC socket?
Opening up the Odin to replace the battery is troublesome i agree, you need to use a dremel and patience for that purpose.
Reply 7 of 7, by Stojke
There is no socket, and its confined inbetween ISA and PCI slot, and a jumpers.
I dont have an good desoldering tool 😒
