First post, by rick6
- Member
I have one of those FIC PA 2013 socket7 motherboards with a AMD k6-2 450 Mhz and a Sound Blaster PCI 128 and whenever i play anything that required 3D acceleration the sound gets quite glitched. If i then play instead with a PCI video card like a voodoo 2 the sound works fine. All under Windows 98.
Is this a known issue with a easy solution which i clearly don't know ? 😁
