Old SCSI Adapter maybe ?
First post, by Bullmecha
I recently started ransacking my hardware, due to the forums here, and found 2 SCSI ISA adapter cards. I looked up the Chipset but found no actual card specs. If anyone has any ideas I am here to learn.
Chipset is a Databook DB86072.
2x 50 pin Connections
Part # or serial # = 47-0045-052E Rev A
Will get a pic if its needed. Thanks in advance.
Just a guy with a bad tinkering habit.
i5 6600k Main Rig
too many to list old school rigs
Reply 1 of 10, by Bullmecha
Guess no one has ever used this. Will post what i figure out then. =)
i5 6600k Main Rig
Reply 2 of 10, by Matth79
Odd... references to that chipset point to it being ISA - PCMCIA rather than SCSI - could there be an additional front panel connector bay somewhere
Reply 3 of 10, by Bullmecha
Maybe I jumped the gun on the SCSI, it was the first impression i got when i saw them. I found no front ports to tie in with them. They are 50 pin IDE Type connections, which again pointed me to SCSI. Maybe these are out of an old Apple PC maybe??? I have no clue atm, but will test them out on a board when i get the chance and see.
i5 6600k Main Rig
Reply 4 of 10, by Maeslin
If there's two such connectors right above one another, it likely goes with a 5¼" bay that would take PCMCIA cards. I have a few of those in a drawer at work. I'll see if I can take a pic or two tomorrow.
Reply 5 of 10, by tayyare
PCMCIA card reader under Windows 98 SE - what should I do next?
It must be something similar. 😀
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 6 of 10, by Bullmecha
This is what I have....
The attachment Scsi maybe.JPG is no longer available
Still not sure what it is but it may be similar to what you linked.
i5 6600k Main Rig
Reply 7 of 10, by Robin4
It doesnt contains a ROM on that board.. Booting from harddisk wont be possible.
Reply 8 of 10, by tayyare
It won't, because it is not SCSI controller either. Look for the chipset, it will point you to a PCMCIA controller. The connector arrangement also points you at that direction.
Just an idea, but It might be PNP card, so if you put it in a board, the BIOS might tell you what the name of the card is, during boot up:
"Initializing PNP cards: Sound Blaster AWE 64 Found..."
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9 of 10, by tayyare
http://www.actiontec.com/157.html
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 10 of 10, by Bullmecha
Did some browsing for a card reader with the 50 pin SCSI connection, all for around $200. Guess I need to do something with these things.
i5 6600k Main Rig
