First post, by FeedingDragon
- Oldbie
Well, imaged the disks (boot disk is 400K and Master Map disk is 320K.) Only, to play the game you have to first create a Map disk. This can be done by using the Master Map disk to create a historical map disk, or using a random generator to create the map disk. The problem is, I can't create the map disk. With 0.74 & SVN builds I get **disk error** as soon as I "insert" the blank disk (CTRL-F4 to the blank 320K/400k/360k/720k disk image.) With the DAUM build it looks likes it's working just fine until the end, when I get **disk error** again.
Further experimentation, and I seem to be able to play by making a copy of the Master Map disk, and just using that copy as the disk image I play from. This does not, however, allow me to create a random map. Meaning every game will be exactly the same 🙁 I'm not sure how it access the disk, but it probably uses some sort of direct access that DOSBox apparently doesn't support. Does anyone know of a way to get it to work?
Feeding Dragon
