Iam only going with the more expensive brands like weller.(very expensive) From my point of view i cant recommending cheap brands. And i totally avoid irons that uses screws to tighten up the welding tip. Mostly when the iron heats up the screw would loose it self. Most important thing is if you choose a high expensive brands, you always find replacement tips and having a longer support range (assortiment) of your product. And also the range of different kind of replacement tips are much higher on expensive brands, then the cheaper ones... The cheaper ones, doesnt perform mostly that good, range of tips are limited and also mosly hard to find.
Good stuff costs you a lot of money.. Actually there isnt a middle way..
I dont know in which country you living on.. So brands will specific in which part of the planet you are on.
Good brands are; Pace, Weller, Hakko. But they would cost you a fortune.
I have also an Aoyue desolder station here.. I cant recommending it if you want to use it for fine solder pads.. It only works great (a sort of) when you want to desolder thinker / normal bigger solder pads.. But avoid it for finer rework, because there are no finer tips for it available.. Only the expensiver brands have...
As on the Aoyue, it doesnt work / great on cpu sockets, IDE headers, memory sockets ect.. Works good on removing an AT style of keyboard socket, or motherboard psu connector. On home electronics like radios, tv`s it would work great, but on computer hardware you need more the high quality stuff.. Every factory that producing motherboards or computer cards using HQ stuff.. The downside of the Aoyue is the stability of the temps..
When its new it would work fine, but after some use the stability would just worse.. Often it stays to cold to work with..
An weller solder iron would costs you about 200-300 euros. But the problem with desolderstations is the vaccuum.. The cheaper ones would require a seperate air compressor and installation on tubing to create your own vaccuum installation.. Only creating one, you need to have the knowledge.. For home users this isnt ideal also because the compressor makes a lot of noise..
Its more ideal if the desolding station have a vaccuum pump installed in the unit.. The downside of this is that it would raise up the price of the whole unit..
For me the ideal way is go for the expensiver way with the vaccuum pump installed, so i dont have to worry about how to make my own vaccuum installation, and wouldnt require an addition of a small noisy air compressor.
