Reply 460 of 27586, by King_Corduroy
I don't think I've ever seen anyone replace a surface mount chip! Very impressive, I had just written it off as impossible.
My retro activity was also bringing a PC back from the dead, my father dragged home an old Pentium MMX computer with a Baby ATX motherboard, it however had serious corrosion on the components around the Li-Ion CMOS battery because it had managed to explode (I've never seen one of those explode before today). But after reading up on the correct way to clean the corrosion off I scrubbed it with vinegar to neutralize the battery acid and then with rubbing alcohol to just remove the junk. I rinsed it with water and let it sit for a day to dry out. Fired it up and BLAMMO it works perfectly! I'll probably be making a quick video on it so look for that to pop up on here. 😁
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 461 of 27586, by dogchainx
ReeseRiverson wrote:
Wow, that is some seriously impressive work you've done there! I've always wondered about some tricks to revive older motherboards, and heck, that one is pretty dang impressive.
What would you guys suggest doing for chips like that, that have bent pins while on a board already? I found a Voodoo 2 3DFX card at a local computer shop for almost nothing, but it had bent pins that do touch each other.
Ditto. I have a few cards that need to be repaired. I've looked at You Tube, went through a few trials, but my "skills" at soldering leave a lot to be desired. My wonderfully cheap Orchid Fahrenheit 1280 card started to boot only blue. I took it out, and noticed a small crack on the holder of a chip. I went to push on it lightly, and the WHOLE CHIP and HOLDER came right off! Now i'm trying to figure out how to just surface mount the chip back on there. Projects projects projects.... 😒
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 462 of 27586, by Shodan486
Reinstalled win95 OSR2.5 like 3 times due to IRQ / Memory address conflicts (coz I change stuff all the time 😜 ).
MOBO: PVI-486SP3 Rev 1.2
CPU: POD-83
RAM: 2x16MB
VIDEO: Matrox Millenium 2MB/Voodoo2 12MB/Video Blaster VT300
AUDIO: SB Vibra16 FM
SCSI: 72GB 15k RPM HDD/YAMAHA CD-RW 16x/ZIP drive + FDD drive
NIC: 3Com Etherlink III
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 463 of 27586, by ReeseRiverson
Plus things like this could be helpful in my 486 Packard Bell since the battery left quite a mess in a certain area.
Reply 465 of 27586, by ReeseRiverson
Anyone know or can determine a good capacitor replacement for this AWE64 Gold I got? The one for the right (red) channel had a broken leg, and no matter or what, I can't get solder to attach. So I think it's best to just replace the thing.
But being a little square cap... I can't really tell. I wish it had the same capacitors my other AWE64 units had, the electrolytics, then I could actually read what they are. 😵
Reply 466 of 27586, by Blurredman
Anyone know or can determine a good capacitor replacement for this AWE64 Gold I got? The one for the right (red) channel had a b […]
I've never really had good results with leadless solder. 😒 What type are you using?
http://blurredmanswebsite.ddns.net/ 😊
Reply 467 of 27586, by brostenen
Try this youtube video about surface mounting.....
https://www.youtube.com/watch?v=b9FC9fAlfQE
EEVblog clip, about how to solder SMD component's.
There are some good tricks and stuff, especially how to use the "reflow" technicue.
And some info about what to NOT do when soldering this way.
By the way. That capazitor looks really bad, as it looks like something went off.
You might want to buy a new one.
Reply 468 of 27586, by keropi
I believe it's a 4,7μf capacitor, it does cay "C4μ7" right?
A 4,7μf/16v replacement should be more than enough and pretty common.
Reply 469 of 27586, by ODwilly
Reese: If the pins are just bent and touching not broken, you could get a pair of thin tweezers and gently bend them back so that they are no longer touching. Maybe heating them up slightly would help? On a side note my retro activity was to put together a semi-gaming dual core Athlon 64 system for my sister. Only a 2.0ghz chip with 1gb of DDR2 but the Geforce 8800gt makes up for it 😊
Reply 470 of 27586, by ReeseRiverson
60/40 rosin core, I have to see specifics when I get home.
-edit-
Found what I do have: http://www.amazon.com/gp/product/B00068IJPO/r … 0?ie=UTF8&psc=1
The pin on that capacitor was broken, I was hoping some solder could grab onto it, and chances are that I just couldn't heat up the tiny spot that was left on the capacitor itself.
Maybe, it was hard for me to tell, but perhaps I can use a multi-meter to test the capacitor on the other channel... 😲
brostenen wrote:
Try this youtube video about surface mounting..... […]
I'll definitely check that out soon, thanks! 😀
Reply 471 of 27586, by jwt27
I used fine tweezers and a stanley knife blade, as shown on the second picture. Anything will do, as long as it fits between the leads 😉
Surface mount soldering is dead easy once you get the hang of it. It's much easier than through-hole soldering IMO.
QFP chips are easy too, as long as you use hot air tools, and shouldn't take more than a few minutes normally. But I don't have this stuff at home 🙁
It's still not working 100% though. The floppy drive interface doesn't work at all. Drive starts spinning on access but it won't read anything. And I tried booting with a Linux LiveCD, but then the keyboard stops working. This doesn't happen with a FreeDOS LiveCD... Also the BIOS won't remember its settings.
All of this is controlled by that Winbond chip so I may have fried it while desoldering (overheating/ESD?), or perhaps there are other bad components on the board. Not unlikely, as there must be a reason why this chip failed in the first place...
Yep, that's a 4.7µF tantalum or polymer.
Reply 472 of 27586, by ReeseRiverson
Okay, then I better try my luck then... I hope it's savable! You know what? I'll go ahead and take a picture of the pins when I get home. 😀
Alright, that'll be on my list of parts to get then. Especially if I can save the AWE64 Gold. I really honestly like these cards. 🤣
Reply 473 of 27586, by dogchainx
Reese...be very very careful bending those pins. I tried to do that with about 15+ pins that were touching on mine. Out of all of those, about 4-5 of the pins lifted off of the solder contact on the PCB. So gentle on the pressure and try to place most of the pressure near where the pins EXIT the chip, and not down near the PCB solder points.
Reply 474 of 27586, by Shodan486
Well I see a lot of dust on the PCB, so one of the reasons may be the pads are not clean enough to hold the solder, the same may count for the cap itself - make sure it is clean, use sandpaper (but carefully) or isopropyl alcohol to clean both the contacts of the pads and capacitor (using a brush helps!).
What soldering tool do you use? Does it heat the surface sufficiently (the PCB ''consumes'' the heat quickly)? The solder you have is OK, maybe additional flux will be required.
CPU: POD-83
RAM: 2x16MB
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 475 of 27586, by ReeseRiverson
Well, I just hope they aren't already in too bad of a case, but I'll use my macro lens on my camera to really get up and close in detail.
Well, that could be, but the capacitor has a broken leg when I got this board. I could clean it up and try again though.
As far as soldering tool, I have a Hakko 703 Solder/Desolder Station. I'll need to get some flux though.
Reply 476 of 27586, by tokroger
played today at my friends house his Atari Lynx handheld. That fat original version, not sissy Lynx II 😀 I remember when I bought mine, almost instantly after it was available. And I think I have to get one of those again. Played Chip's Challenge and Slime World and still love those games... I also had original GameBoy and Sega Game Gear. Why, oh why I let them go...
:EDIT: shiiiit.... http://www.ebay.com/itm/Atari-LYNX-The-Comple … =item43c6ee69c1
Reply 478 of 27586, by PhilsComputerLab
Built a new test bench / Retro Gaming PC for Splinter Cell Pandora Tomorrow:
It's a Core i5 2500, 4 GB RAM, 7800 GTX, X-Fi, XP SP3
I'm using Bandicam for capturing game footage and this will by first "Let's Play Period Correct" video series 😀
First video is uploading but several GB because I play at 1600 x 1200 and render in 4K resolution 😀
YouTube, Facebook, Website
Reply 479 of 27586, by Skyscraper
philscomputerlab wrote:
Built a new test bench / Retro Gaming PC for Splinter Cell Pandora Tomorrow: […]
Very nice! That system is almost fast enough 😉
I should get going with building some more yearly builds or bench some more AGP cards.
My AGP test bench rig is giving me headaches though, the Soyo KT333 socket A board with universal AGP is very picky when it comes to video cards. It only works with all AGP 8X slotted cards, when it comes to AGP 2X and universal AGP cards its hit and miss, 50% works 50% dosnt. All cards are tested and found working using other systems. Perhaps I have used the Soyo board to test a bit to many faulty video cards but it still works great with the cards that work and its seems very random which cards works and which cards dosnt.
For some reason I feel more like building a total overkill Pentium-D rig to see what type of performance I can get with a Netburst CPU and some semi modern GPU.
Will it handle Crysis?
