which vga/3d card for Pentium 1 233MMX?
First post, by nemail
Hi
at the moment I'm focussing on my P1 233MMX rig with
FIC PT-2007 Mainboard
Pentium 1 233MMX
YMF719 sound card
the question is, what would fit better:
S3 65 VIRGE VER 1.1 + 3Dfx Creative Labs CT6670 Voodoo 2 / 8MB
or
Voodoo 3 PCI 16MB
or
Hercules Stingray 128/3D (old version with daughterboard)
I've also got a P2-333 system and a K6-2 550 (or so) but still one or two voodoo 3 3000/3500 agp left to distribute on the systems.
into which systems would you install which cards?
i guess the stingray is more a collectors object than a well-performing 3d card, isn't it?
Reply 1 of 33, by kixs
Hercules Stingray 128/3D actually has 3dfx Voodoo Rush for 3D part. It is slower then Voodoo1 but not by much.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 2 of 33, by PhilsComputerLab
V3 would be held back somewhat.
A V1 would be a good match to be honest for a Pentium machine. Or a V2 but that means more mucking around getting Glide games to work from that era.
YouTube, Facebook, Website
Reply 3 of 33, by Robin4
I would choose to go for a period correct 3d accelerator (could be a Riva 128 / Riva TNT or maybe a S3 Savage4 PRO+ card. With a 3dFX one..
Those 3d Virge cards and other 2D cards, commonly are just worse performance cards..
Reply 4 of 33, by nemail
heya!
i remember having a p1 166 with a voodoo 3 2000 pci performing very well, so i guess voodoo 1 might be too slow (besides, i dont have one).
i only have the cards mentioned in the first post so maybe s3 + voodoo 2 would be a good choice? the s3 is a great 2d card, or isnt it?
and wouldnt the voodoo 2 be too slow for the 233mmx?
Reply 5 of 33, by PhilsComputerLab
Pentium machines are quite slow and will hold back V2 easily. But you do get the benefit for higher resolutions.
But CPU performance in general is important with 3dfx cards.
Very rough I would recommend:
Pentium: V1
Pentium 2: V2
Pentium 3: V3+
Reply 6 of 33, by nemail
wow ok.. thanks!
well, as i don't have a voodoo 1 i'd have to stick to voodoo 2 on my pentium 1 (which resolutions can i expect to work flawlessly?)
my p2-333 would then get the voodoo 3 as the only voodoo 2 i own already is installed in the p1 rig
and my p3-1000 (so370) already has a v5 5500 anyway 😁
voodoo 3 3000/3500 would fit for amd k6-2/550 or is that card too slow for that cpu?
Reply 8 of 33, by PhilsComputerLab
V1: 640 x 480
V2: 800 x 600
V2 SLI: 1024 x 768
V3: 1600 x 1200 and maybe higher if you have a monitor that support it
Reply 9 of 33, by nemail
ok thx, i'll think about it!
Reply 10 of 33, by havli
About the CPU limitation of Voodoos:
Voodoo Graphics / Rush -> Pentium 166
Voodoo2 / Banshee -> Pentium 2 400 / K6-3 500
Voodoo2 SLI -> Pentium 3 800 / Athlon 800
Voodoo3/4 -> Pentium 3 1000 / Athlon 1000
Voodoo5 -> Pentium 4 3GHz+ / Athlon XP 2GHz+
With these CPUs 99% games in the given time frame (V1, V2, V3, V4, V5) will run on full power.
Reply 11 of 33, by nemail
havli wrote:
About the CPU limitation of Voodoos: […]
hmm thats interesting - i did 3dmark 99 with voodoo2/8mb and voodoo 3 2000 16 mb and got about 100 points more with the voodoo 3 card in my 233mmx system. what does that mean?
Reply 12 of 33, by alexanrs
It just means that the that setup is faster in a few tests that are not that limited by the CPU. That doesn't necessarily translate to real-world performance, as games might be limited by the CPU in practice.
Reply 13 of 33, by havli
Actually, 3DMark 99 is CPU bound quite a lot. 100 points difference isn't that much - it can be caused by better driver optimalisation or maybe the Voodoo3's unified memory architecture (3DMark likes high memory bandwith). Here is an example how Voodoo2 and 3 scores in 3DM99 with strong CPU.
Voodoo2 @ 105 MHz -> 4016 points http://hwbot.org/submission/2348401_havli_3dm … doo2_4016_marks
Voodoo2 SLI @ 105 MHz -> 6215 points http://hwbot.org/submission/2348401_havli_3dm … doo2_4016_marks
Voodoo3 PCI @ 200 MHz -> 8124 points http://hwbot.org/submission/2348448_havli_3dm … _pci_8124_marks
This is another part of my CPU test.
3DMark99 is running with default settings and testing was done on Windows XP - so the scores may be lower than similar win98-based system would do. Still the scalling with more CPU power is very clear.
Reply 14 of 33, by Dreamer_of_the_past
From what you have the answer is the Voodoo3.
Reply 15 of 33, by nemail
whoa huge difference between the cpus...
as i have more than one retro gaming rig i decided to use my voodoo 2 + s3 virge 325 in my pentium 233mmx box (which card would you recommend instead of the S3 or is it ok?) and to use my voodoo 3 pci in my p2-333 rig as it doesnt have an agp slot (hp vectra desktop) and the voodoo 3 is my most powerful retro pci card (all newer rigs have agp and i have plenty of agp cards).
only downside is, i don't have a vga loop cable for the voodoo2, i've ordered a 0,5m vga extension cable, hopefully there won't be too much signal loss...
Reply 17 of 33, by nemail
cool thing, but unfortunately my only system which compares to your test system is occupied by my voodoo 5 and its kind of "finished" so i don't want to mess around with it too much...
Reply 18 of 33, by nemail
ok is there an alternative to 3dfx cards?
turns out that my voodoo 2 seems to be faulty, as well as my hercules stingray 128/3D
the V2 just disappeared from dxdiag (only s3 is shown now) and also 3dmark 99 doesn't see it, although i can see it in the device manager. that happened during the system ran (1st time i opened dxdiag the voodoo was there, second time it wasn't). reboot, driver reinstall etc. didn't help.
as there also were random lockups with the voodoo 2, i guess it really may be faulty (i used creative and also most recent reference drivers).
the hercules stingray makes a lot of image noise in 2D mode (desktop) and draws random horizontal lines (not through the whole display).
are there any easy-obtainable but decent performing 3d accelerators from that time period, comparable to voodoo 2/3?
thanks
Reply 19 of 33, by Skyscraper
It sounds like driver issues to me, the drivers are probably overclocking the cards.
At least I think this is what is happening to the Voodoo Rush.
