goblins
First post, by Unregistered
can'g get the sound in goblins1 when I run it with vdms. Is there a particular way you should configure vdms in there?
Reply 1 of 2, by vladr
You'd have to use the EmuPPDAC module + SPEEDSET (see this and this). Beware, however, that on fast machines Gobliiins 1 stops working altogether (error -7, divison by 0). I strongly recommend that you try DosBox, it loads up Gob1 just fine. The only Goblins that works just swell under VDMSound is Goblins 3 and, to a certain extend, Gobliins 2 (needs SPEEDSET). DosBox is your best bet for Gob1 and Gob2.
V.
Reply 2 of 2, by Snover
Or play it on a (far superior) Amiga (or Amiga emulator--UltraHLE--as it were).
Yes, it’s my fault.
