First post, by dosquest
Hey guys. In currently putting together a win98 PC and I'm wondering what the easiest to config and use with windows 98? I've had hit and miss with some v
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 1 of 17, by dosquest
Well. DgVOODOO seems to be working. Sorta. When I'm in NFS II SE the mouse doesn't show up in the pause menu.
Reply 2 of 17, by PhilsComputerLab
W9x? Why not use a real Voodoo?
Personally I like nGlide because it's so easy to use and has a good scaler.
Reply 3 of 17, by Stiletto
dgVoodoo 1.x (Direct3D) and/or Zeckensack or OpenGlide (OpenGL) are probably the best bet. There's some even older ones if you're on a particularly ancient graphics card or only running UltraHLE tho.
Because the Windows forum is intended to be the place to discuss "Getting old Windows games working", not "collect old graphics cards", much as I love Voodoo cards - this ain't Marvin. 🤣
If he IS discussing running on a Pentium II or what not, then we can move it into Marvin. 😉
do the Fandango!" - Queen
Stiletto
Reply 4 of 17, by dosquest
Why not real hardware? Because I haven't found a good bargain on a voodoo. As for wrapper, dgvoodoo seems to be working OK. I still need to tweak it. Some texture flickering and at some points in nfs ii se you can see the road texture buffer. The last stable version of dgvoodoo I can use is 1.4 because in 1.5 its a beta and beyond he discontinued support for 9x.
Reply 5 of 17, by dosquest
When I use open glide it crashes.
Reply 6 of 17, by PhilsComputerLab
Fair enogh.
DQ give nGlide a go. Copy the ZIP to the game folder. Using 7-ZIP or something similr unzip into the gaming folder or DOSBox folder if it's for example a GOG.com game.
Run the config utility, select native resolution and 4:3 aspect ratio.
I have only tried two games so far: Tomb Raider and Screamer 2 but at least in those games it was perfect.
Reply 7 of 17, by dosquest
Idk if it will work. I'm using native win 98se on hardware.
Reply 8 of 17, by mr_bigmouth_502
It's hard to find Voodoo cards around here, so I can see why one would want to run a Glide wrapper under Win9x.
Reply 9 of 17, by leileilol
I used to use XGL200 and (later on into the shader 1 and 2 era) Zeckensack on Windows98SE/ME IIRC, though it wasn't an ambitious use of glide (no UnrealEngines or DOS glide chains)
Debian's fucked
Reply 10 of 17, by Gamecollector
If you have a DX9 videocard - use nGlide. I can't test new versions (my Radeon X850 PE is dead) but all old versions are fully Win9x compatible.
For DOS glide games (glide2x.ovl) you can use dgVoodoo or GliDOS.
Reply 12 of 17, by Stiletto
Much like feipoa's thread before: Carmageddon D3D acceleration in DOS
It's rather hard to categorize! PC Emulation might be better, true.
Stiletto
Reply 13 of 17, by dosquest
Well. I'm not so much as emulating, because its on actual hardware. So far, I have gotten NFS II SE running at fairly fast frames. Now to test other games. I'm starting to think the glide api was just smoke and mirrors with texture compression accounting for the speed.
Reply 14 of 17, by Stiletto
What is the hardware you are using? That may yield some better suggestions...
Stiletto
Reply 15 of 17, by dosquest
Pentium III 500mhz
Ati rage pro 128 4xl 16mb
Reply 16 of 17, by Rekrul
Beyond that, he discontinued support for XP as well...
Reply 17 of 17, by leileilol
that's a given considering there is no DirectX11 on XP.
Debian's fucked
