First post, by trgupta
i am unable to run th 16 bit exe files in DOSBox installed in window 8.1 (64-Bit)
upon running the said exe from properly mounted drive , i am geting following message
" this a a Window 16-bit executable"
i have pasted screenshot of the same in attached file for your reference
looking forward for the solution kindly help!
rgds
Reply 1 of 3, by mr_bigmouth_502
DosBox won't run Windows programs unless you run Windows within it, but that's unsupported. From the sounds of it, you need a copy of Windows 3.1, which from my experience works just fine in DosBox, as it's really an elaborate DOS program.
