First post, by Matth79
Downloaded some ZIP archive stuff (shareware/freeware) to try in DOSbox, and none of my programs could handle the old ZIP format.
Eventually took the line of least resistance ... real era-correct PKUNZIP running inside DOSbox.
The title of your post is somewhat misleading, as it's not an issue with DOSBox but rather with the archive utilities you are using. PKZip evolved over time, and earlier compression methods (Shrink, Reduce, Implode) are not supported in some modern archive programs that only support later compression methods (usually Deflate).
wrote:(Shrink, Reduce, Implode...Deflate)
Hee, hee, have always loved these compression method identifiers 😀.
Here's a quick rundown of the sorts of compression they indicate:
I always mass-extracted old zip archives with both WinRAR and 7-zip and never experienced many cases of decompression failure, except for actual corrupt archives.
Debian's fucked
