First post, by 386SX
I'd like to ask your experiences about which components (ICs, heatsinks, cards, passive/active components) you found over the years running at high temperatures at STOCK frequencies/voltages considering the sizes of building processes available at the time they were built.
In my past and actual experience I found running at high temperatures these parts:
1) Overdrive 66Mhz (486) 5v (stock with passive slim heatskin, impossible to press)
2) M3D (PCX2) PCI 4MB (stock without any heatsink unconfortable to long press)
3) K6 233Mhz 3,2v (with a stock 3 cm heatsink plus fan) still warm a lot the case I've built
4) V3 2000 AGP (stock slim heatinsk with a strong Athlon it gets hot quiet close to the Overdrive)
5) Savage 2K 32M (with a big stock heatsink running hot even if not that much I ever heard)
6) Athlon 1000 on socket (run hot but I remember the 1100 runnning much higher but probably not)
7) (off topic) X360 first revision...( đ” )
Let's hear yours!
Bye
