Wing Commander 3
First post, by PitschBlack
hi
is there anyone who get this game running or must i wait till another dosbox version????!!!! 😕
greetz 😅
Reply 1 of 13, by priestlyboy
I've had it running not too bad but could be a lot better in the CVS Version of DOSBox.
Ieremiou
Helping Debug DOSBox.
Reply 2 of 13, by PitschBlack
well... the installation does not even function, black screen it tries the video resultion????
by the way what is this dosbox version you mentionesd???
Reply 3 of 13, by priestlyboy
It's the unofficial CVS version that I compile.. See my Sig for the forum which hosts the build.
Ieremiou
Reply 4 of 13, by MajorGrubert
Unless you really need to run DosBox under Linux, I suggest you try running WC3 under Windows XP with VDMSound. I was able to finish the game using Windows XP, VMDSound 2.1 and the alternate joystick drivers you can find here in the Wing Commander CIC site.
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
Reply 5 of 13, by PitschBlack
thanks for answering....the game is working or at least playable.....but the sound and play sequences are still crackling?!
i tried to fix it with the frameskip and the emulation speed now its at leat playable....any suggestions????
thx for the joystick patch...works fine
Reply 6 of 13, by Hazekel
Guys, I use Windows 98se and I can run the game, except that the video skips because my DVD ROM is too fast. Is there a way to emulate the DVD ROM speed through DOSBOX?
Reply 7 of 13, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
NO. But there are programs to slow down CD/DVD in Windows (Nero Drive Speed, CD Bremse).
Mirek
Reply 8 of 13, by robertmo
Hazekel: wouldn't it help you if you make a CD image of it?
Reply 9 of 13, by THE_WUQKED
Wing Commander III runs way too slow under the current DosBox 0.61. But thx to the newer CVS versions, it's really playable. - No sound crackling and movies play perfect for me. Now there are only two probs left:
-when hitting enemies in fight, it slows down a lot. Still playable, but very annoying
-on my rig it's quite unstable. After finishing some missions dosbox just crashes back to desktop.
Reply 10 of 13, by IceAIM
What kind of joystick are you using? Is it a usb gamepad or a traditional gameport joystick?
Unfortunately I only have a usb gamepad, and I hear that the arrow keys do not work under xp. 🙁
Reply 11 of 13, by IceAIM
Is this problem common with all DVD rom drives, or only some? How can this problem be resolved?
Reply 12 of 13, by IceAIM
To clarify, the above post is in regards to the following quote:
Where can you get Nero Drive Speed?
