First post, by adolobe
I have an old Packard Bell PB610, Im almost certain this is my motherboard http://www.uktsupport.co.uk/pb/mb/430.htm but not 100%
I was getting real time clock failure and the old battery was starting to leak so I removed it, and the jumper on J24. Then I installed a Tadiran TL-5242/w backup battery.
The bios will now hold any changes I make except the time, I also get a real time clock failure message at the start of the bios bootup and half of the time on boot up I wont get anything instead I get 3 long beeps and 2 short beeps.
Anyone have an ideas what the problem might be?
Reply 1 of 2, by smeezekitty
"starting to leak"
I wouldn't be surprised if that was the source of the problem. Is there any corrosion on the board?
Reply 2 of 2, by adolobe
smeezekitty wrote:
"starting to leak"
No corrosion, I removed the old battery and cleaned the solder points. All the corrosion was on the battery tips lucky and not on the motherboard
