First post, by Diodon
Hello, sorry for my poor english first, i'm french 😉
dosbox 0.74
windows 7 64bit
Theire is my problem, i launch without problem my program (image 1)
But i need the program to save the data in another directory because it will be quiclky overload with lot of files.
In my program when i try to change the data directory it fail, invalid name or directory not found (image 2)
I want the program tu run from
F:\XRD\test.bat
and save in
F:\Data\
Is this possible ?
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
to change a directory you need to use
CD
Please be adviced that DOSBox is not intended for any serious business work. It contains bugs.
Water flows down the stream
Reply 2 of 6, by Diodon
how i use cd command in that case ?
I know that dosbox was developped for gaming purpose, i used first for that myself, but i have some old program, and with windows xp ending i have no choice, i can deal with bugs for now. The time to develop a new program of our own.
For the cd command, i use this in dosbox or in my program ?
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
mount F F:\
f:
cd XRD
test.bat
Reply 4 of 6, by Diodon
Ho my god that's so obvious now i see it.
You go on F then in XRD.
Thanks a lot you saved my day.
Reply 5 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
Exactly!
Reply 6 of 6, by Diodon
Thank you again, tag as solved ^^
