First post, by dosquest
I'm running windows 98se and I have an at I rage pro 4xxl 16mb which doesn't like glquake. It crashes. I vaugely remember something to do with rage cards not liking glquake.
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 2 of 8, by leileilol
Upgrade your drivers for a more mature OpenGL ICD and remove opengl32.dll from the Quake folder. I've had Rage Pros working in GLQuake before. The only big difference i've seen are particle edges and noisier dithering.
you should even be able to run quake 3 on that card.
Debian's fucked
Reply 3 of 8, by dosquest
Isn't glquake 97 a windows port?
I've deleted opengl32.DLL
It starts and plays fine. On exit it crashes. I hit quit then press Y and it does an illegal operation error. I've Reinstalled windows 98se 12 times already. Swapped hard drives. Swapped rage cards, a different rage card plays it ok and doesn't crash but that one doesn't support fog table.
Reply 4 of 8, by Zup
Older ATI cards had their own miniGL pack. Have you tried installing it?
I'm selling some stuff!
Reply 5 of 8, by dosquest
Where would I find it?
Reply 6 of 8, by idspispopd
Which card do you have exactly? 16MB cards are usually Rage 128 based, when I search for "rage pro 4xxl" I mostly get hits for "Rage 128 Pro 4XL".
Reply 7 of 8, by filipetolhuizen
This is the stock card that comes with the PowerMac G3 B&W. GLQuake was also ported to Mac OS Classic and I was able to run it with that card. Remember that there are different versions of GLQuake out there, maybe you got an early one or the drivers you're using has some bugs.
Reply 8 of 8, by matze79
You can also use Scitech GLDirect, its a OpenGL to Direct3D Wrapper.
Now Freeware, Serial is also freely avaible.
http://www.majorgeeks.com/files/details/gldirect.html
EDIT:
Ok i tested this with Rage Mobility.. doesnt work well.
EDIT#2:
Now testing glquake with TitaniumGL.
Works, but is buggy.
Framerate is well.
(Testing on XP with GPU accelrated TitaniumGL)
