First post, by VirtuaIceMan
- Oldbie
Master Rallye, by Steel Monkeys/Microids, takes a long time to switch between each menu screen (it gets there eventually!). I've found if you alt-tab out of the game and back in, then often the next menu is already there, you just have to wait before it appears! So alt-tabbing like crazy between screens speeds things up, but is a *little* impractical.
Anyone care to take a look at this one? The same issue affects the game running in a window, so it's not something to do with a fullscreen lock of any kind (if you run the game in a window, drag the border slightly to speed up the screen transitions).
It's a bit odd!
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
