First post, by Zup
- Oldbie
How can I use a floppy disk image in plain DOS?
I have to run a program that needs a floppy drive, but the floppy drive on that computer is broken (and it is a laptop, so no standard floppy can be used). I'd like to use a program that could make a disk image as "A:" to run the program. The virtual floppy will be a standard 720k disk image (=737280 bytes) empty or pre-formatted, so I don't need any protection emulation.
The program is a BIOS update, so it will run without XMS or EMS enabled.
Thanks.
