First post, by kjliew
Attach the clean patch to enable kekko's voodoo1 emulation and gulikoza's glide pass-through at the same time in single DOSBox build. Kekko voodoo1 emulation has been updated based on the latest build as in VIDEO - 3dfx voodoo emulation (SDL1).
Just a reminder so that you don't get confused with the placement of GLIDE2X.DLL and GLIDE2X.OVL. Kekko's voodoo1 emulation must use the real version from Diamond Monster3D drivers. Gulikoza's glide pass-through includes special GLIDE2X.DLL and GLIDE2X.OVL to thunk glide APIs from guest to host.
All credits go to Kekko and Gulikoza for their contributions to bring 3Dfx gaming into life for DOSBox on modern machines.
    v1emu_glide2h_r4335.txt
    420.92 KiB
    227 downloads
    2-in-1 Glide pass-through & Voodoo chip emulation
Reply 1 of 12, by MastaG
It fails to build for me.
I'm building with OpenGlide...
i686-redhat-linux-g++ -DHAVE_CONFIG_H -I. -I../.. -I../../include -I /usr/local/include/openglide -I/usr/include/c++/5.1.1/i686-redhat-linux -I/usr/lib/gcc/x86_64-redhat-linux/5.1.1/include -I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -m32 -mno-ms-bitfields -MT voodoo_emu.o -MD -MP -MF .deps/voodoo_emu.Tpo -c -o voodoo_emu.o voodoo_emu.cpp
In file included from voodoo_opengl.h:33:0,
from voodoo_emu.cpp:81:
voodoo_vogl.h:28:34: fout: ‘void (* glActiveTextureARB)(GLenum)’ redeclared as different kind of symbol
extern PFNGLACTIVETEXTUREARBPROC glActiveTextureARB;
In file included from /usr/include/SDL/SDL_opengl.h:46:0,
from voodoo_vogl.h:24,
from voodoo_opengl.h:33,
/usr/include/GL/gl.h:1971:23: note: previous declaration ‘void glActiveTextureARB(GLenum)’
GLAPI void GLAPIENTRY glActiveTextureARB(GLenum texture);
voodoo_vogl.h:29:36: fout: ‘void (* glMultiTexCoord4fARB)(GLenum, GLfloat, GLfloat, GLfloat, GLfloat)’ redeclared as different kind of symbol
extern PFNGLMULTITEXCOORD4FARBPROC glMultiTexCoord4fARB;
/usr/include/GL/gl.h:1999:23: note: previous declaration ‘void glMultiTexCoord4fARB(GLenum, GLfloat, GLfloat, GLfloat, GLfloat)’
GLAPI void GLAPIENTRY glMultiTexCoord4fARB(GLenum target, GLfloat s, GLfloat t,
voodoo_vogl.h:30:37: fout: ‘void (* glMultiTexCoord4fvARB)(GLenum, const GLfloat*)’ redeclared as different kind of symbol
extern PFNGLMULTITEXCOORD4FVARBPROC glMultiTexCoord4fvARB;
/usr/include/GL/gl.h:2000:23: note: previous declaration ‘void glMultiTexCoord4fvARB(GLenum, const GLfloat*)’
GLAPI void GLAPIENTRY glMultiTexCoord4fvARB(GLenum target, const GLfloat *v);
voodoo_emu.cpp: In functie ‘void init_fbi(voodoo_state*, fbi_state*, int)’:
voodoo_emu.cpp:566:14: fout: ‘FALSE’ was not declared in this scope
f->vblank = FALSE;
voodoo_emu.cpp: In functie ‘UINT32 register_r(UINT32)’:
voodoo_emu.cpp:2758:25: fout: ‘TRUE’ was not declared in this scope
update_statistics(v, TRUE);
Makefile:438: recept voor doel 'voodoo_emu.o' is mislukt
make[4]: *** [voodoo_emu.o] Fout 1
Any ideas?
Reply 5 of 12, by Yesterplay80
A quick question about OpenGlide: What exactly is it required for? Is it used as default wrapper for gulikozas patch? Is any external DLL still required or can other wrappers like nGlide or dgVooDoo2 be used as well?
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
Reply 6 of 12, by kjliew
OpenGlide is a Glide wrapper that emulates Glide2x 2.4 APIs similar to dgVoodoos and nGlide. Yes, you can replace it with dgVoodoos or nGlide. There is no so-called default wrapper for Glide pass-through, it just loads the 1st instance of Glide2x DLL in the search path. OpenGlide plays a significant role for development because it is open-sourced, based on OpenGL technology which makes it portable to any systems with OpenGL. Its Glide emulation is not stellar by today's standard, which has been greatly surpassed by dgVoodoos and nGlide, and has not been maintained for years. I believe it is the only Glide emulation solution for Linux and MacOS (from MacGlide a fork of OpenGlide) today. We shall see if nGlide with Vulkan backend will make a break-through for non-Windows system, especially Linux.
I do hope to see zeckensack's GlideWrapper will still be around and he would be able to open source it to help Linux to catch up with Windows on Glide emulation. I have been trying to contact him but so far to no avail.
Reply 7 of 12, by robertmo
I think the dosbox.conf descriptions should be this way:
# voodoo: Enable VOODOO emulation.
# glide: Enable glide pass-through to external wrappers (eg. nGlide, dgVoodoo 2): true,false.
And glide enabled as default as both can be enabled at the same time right now.
Reply 8 of 12, by fr500
this removes kekko's GL patch right? you can get either kekko's software, or the glide wrapper one with GL.
For my fork the wrapper approach doesn't work. Any way you can let me know how to fix vanilla gekko's patch?
Reply 9 of 12, by kjliew
No. It's called 2-in-1, so both kekko's voodoo chip emulation and gulikoza's Glide pass-through are included and both can be active at the same time in single build.
Reply 11 of 12, by MastaG
@kjliew could you please rebase the patch on top of the latest dosbox svn?
It doesn't apply any longer..
patch -p1 <../../Downloads/v1emu_glide2h_r4228.txt
patching file configure.ac
Hunk #1 succeeded at 579 (offset 25 lines).
patching file include/glide.h
patching file include/glidedef.h
patching file include/logging.h
Reversed (or previously applied) patch detected! Assume -R? [n] n
Apply anyway? [n] y
Hunk #1 FAILED at 28.
1 out of 1 hunk FAILED -- saving rejects to file include/logging.h.rej
patching file include/Makefile.am
Apply anyway? [n] y
Hunk #1 FAILED at 36.
1 out of 1 hunk FAILED -- saving rejects to file include/Makefile.am.rej
patching file include/mem.h
patching file include/pci_bus.h
Apply anyway? [n] y
Hunk #1 FAILED at 19.
Hunk #2 succeeded at 86 (offset 3 lines).
1 out of 2 hunks FAILED -- saving rejects to file include/pci_bus.h.rej
patching file include/video.h
Hunk #1 FAILED at 59.
Hunk #2 succeeded at 82 with fuzz 2 (offset 13 lines).
1 out of 2 hunks FAILED -- saving rejects to file include/video.h.rej
The next patch would create the file include/voodoo.h,
which already exists! Assume -R? [n] n
Apply anyway? [n] y
patching file include/voodoo.h
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED -- saving rejects to file include/voodoo.h.rej
patching file src/cpu/paging.cpp
Apply anyway? [n] y
Hunk #1 FAILED at 144.
Hunk #2 FAILED at 160.
2 out of 2 hunks FAILED -- saving rejects to file src/cpu/paging.cpp.rej
patching file src/debug/debug_gui.cpp
Apply anyway? [n] y
Hunk #1 succeeded at 252 with fuzz 2 (offset 2 lines).
patching file src/dosbox.cpp
Hunk #1 FAILED at 76.
Hunk #2 FAILED at 527.
Hunk #3 succeeded at 770 (offset 26 lines).
2 out of 3 hunks FAILED -- saving rejects to file src/dosbox.cpp.rej
patching file src/gui/sdlmain.cpp
Hunk #1 FAILED at 49.
Hunk #2 succeeded at 1315 with fuzz 1 (offset 877 lines).
Hunk #3 succeeded at 1965 (offset 1115 lines).
Hunk #4 succeeded at 2956 (offset 1290 lines).
Hunk #5 succeeded at 3409 (offset 1303 lines).
Hunk #6 FAILED at 2232.
2 out of 6 hunks FAILED -- saving rejects to file src/gui/sdlmain.cpp.rej
patching file src/hardware/glide.cpp
patching file src/hardware/Makefile.am
Hunk #1 FAILED at 2.
1 out of 1 hunk FAILED -- saving rejects to file src/hardware/Makefile.am.rej
patching file src/hardware/memory.cpp
Hunk #1 FAILED at 23.
Hunk #2 FAILED at 140.
Hunk #3 succeeded at 194 (offset 3 lines).
2 out of 3 hunks FAILED -- saving rejects to file src/hardware/memory.cpp.rej
patching file src/hardware/pci_bus.cpp
Hunk #2 succeeded at 448 with fuzz 1 (offset 30 lines).
Hunk #3 succeeded at 518 (offset 30 lines).
1 out of 3 hunks FAILED -- saving rejects to file src/hardware/pci_bus.cpp.rej
patching file src/hardware/pci_devices.h
Hunk #1 FAILED at 16.
1 out of 1 hunk FAILED -- saving rejects to file src/hardware/pci_devices.h.rej
patching file src/hardware/vga_s3.cpp
The next patch would create the file src/hardware/voodoo.cpp,
Reply 12 of 12, by kjliew
Checked latest SVN at r4292, it still applies.
$ patch --dry-run -p0 -i ~/Downloads/v1emu_glide2h_r4228.txt
checking file ./configure.ac
checking file ./include/glide.h
checking file ./include/glidedef.h
checking file ./include/logging.h
checking file ./include/Makefile.am
checking file ./include/mem.h
checking file ./include/pci_bus.h
checking file ./include/video.h
checking file ./include/voodoo.h
checking file ./src/cpu/paging.cpp
checking file ./src/debug/debug_gui.cpp
checking file ./src/dosbox.cpp
checking file ./src/gui/sdlmain.cpp
Hunk #4 succeeded at 1671 (offset 4 lines).
Hunk #5 succeeded at 2111 (offset 4 lines).
Hunk #6 succeeded at 2237 (offset 4 lines).
checking file ./src/hardware/glide.cpp
checking file ./src/hardware/Makefile.am
checking file ./src/hardware/memory.cpp
checking file ./src/hardware/pci_bus.cpp
checking file ./src/hardware/pci_devices.h
checking file ./src/hardware/vga_s3.cpp
checking file ./src/hardware/voodoo.cpp
checking file ./src/hardware/voodoo_data.h
checking file ./src/hardware/voodoo_def.h
checking file ./src/hardware/voodoo_emu.cpp
checking file ./src/hardware/voodoo_emu.h
checking file ./src/hardware/voodoo_interface.cpp
checking file ./src/hardware/voodoo_interface.h
checking file ./src/hardware/voodoo_opengl.cpp
checking file ./src/hardware/voodoo_opengl.h
checking file ./src/hardware/voodoo_types.h
checking file ./src/hardware/voodoo_vogl.cpp
checking file ./src/hardware/voodoo_vogl.h
