Reply 6660 of 58164, by Skyscraper
wrote:wrote:This is the 6th Geforce 8800 GTX I have bought this winter... and the 3rd working one. Finally I can mess around with G80 tripp […]
Finally I can mess around with G80 tripple SLI.XFX Pine Group Geforce 8800 GTX. The factory OC for this card is 630/1000 up from 575/900.
The GPU on the Geforce 8800 Ultra is only clocked at 612 MHz so this card should be just as fast.
<snip>Make sure the clock speeds on both core and memory all match, nvidia SLI is picky about this on all generations of cards, new and old. You can put mismatched overclocked/not-overclocked cards together, but unless you manually match the clocks, you'll see bluescreens and crashes and all sorts of nastiness.
Good to know.
I will sort that with MSI Afterburner 😀
I did run SLI with two 8800 GTX with different clocks without issues when I built my "2006 system" but that was probably the exception that proves the rule.
