No sound on Discworld
First post, by Someone
I've tried with many configs (soundcard : Soundblaster SB!Live), and only the MIDI music can be heard when AdLib Output is SB!live and not the default one. The problem is not coming from the game, I have the speech files that should be played in my directory (english.idx).
Please help 😦 !
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
The game works perfectly in DOSBOX. BTW: if you use version from Underdogs, I hope you downloaded the patch from the same page on Underdogs as well! If I remember it well, it is needed for sound to work.
Mirek
