Geoworks 2.0 -> Tetris
First post, by waltgallus
Windows 8.1 64bit
DosBox 0.74
DFend Reloaded 1.4.2
Geoworks 2.0 --> Tetris
Hi
I have attached the DosBox configuration file. I try to run Tetris (in Geoworks) with DFend Reloaded. I get the error message "Keine gültigen Schriftdateien im USERDATAFONT-Verzeichnis (KR-29)" = "No valid fonts in USERDATA/FONT file (KR-29)". The German letter "ü" is not shown correctly. The author of DFend Reloaded says that configuring Geoworks is tricky and the error has nothing to do with his application. I managed to run Tetris on 3 other computers:, 2 of them with Windows 8.1 32bit and one with Windows 8.1 64bit. As I am a newbie I do not know what additional information could be helpful.
Thanks very much in advance and kind regards
Walt Gallus
Reply 1 of 2, by leileilol
Have you installed and run Geoworks booted from a mounted drive image instead of a directory, with MS-DOS (5.0 or better) installed? PC/GEOS has issues in Dosbox without it
You could also try PCem to see if your issue also exhibits there.
FUCK "AI"
Reply 2 of 2, by waltgallus
Hi leileilol
Thanks for your assistance. However I am a newbie and do not really understand your suggestion. Could you please explain step by step what I should try. I would very much appreciate this additional information.
Walt Gallus
