First post, by noshutdown
topic shall be self-explanatory.
are there any dos games demanding pentium+16mb or higher as minimum requirement, and uses 16bit colors video mode?
Reply 1 of 17, by smeezekitty
Are there DOS games requiring Pentium? Sure lots.
Tomb Raider and Quake come to mind. While they "run" on a 486, they are quite slow without Pentium.
I am quite sure there are also games that require 16MB of RAM as well.
No idea about high color/true color in DOS games.
Reply 2 of 17, by leileilol
Extreme Assault is one of those and can even use MMX for bilinear filtering some sprites.
Armored Fist 2 can really choke also, probably even more so than Comanche 3.
FUCK "AI"
Reply 3 of 17, by jesolo
Tunnel B1 (not a very well known game) that has 16-bit colours video mode requires quite a fast Pentium based CPU to run smoothly.
Problem is that this game doesn't support 3D hardware (all rendering is done in software).
Basically, any SVGA (640x480 or higher) based DOS game requires a Pentium CPU to run smoothly (Duke Nukem 3D and Privateer 2 also comes to mind).
Reply 4 of 17, by HighTreason
I always found Blood was very prone to slowdown, even on some fast Pentium II machines... In fact, it still occasionally hiccuped on an Athlon 1500+ as well as if you put the CD in, you have to wait for the track to loop every time it ends. Woefully inefficient in my opinion.
Comanche 3 is heavy, but at least it has good reasons for it. Blood's revision of the Build engine was optimized for Pentium processors as far as I remember, though actually running it well on a Pentium is a bit of a big ask and rarely produces good results unless you crank all the settings down, especially later versions such as 1.21 where it ran even worse and was almost unplayable on the 75MHz Pentium baseline they had set.
Reply 5 of 17, by carlostex
Grand Prix 2
Reply 6 of 17, by F2bnp
I believe Fallout demanded 32MB in DOS.
Reply 7 of 17, by noshutdown
smeezekitty wrote:
Are there DOS games requiring Pentium? Sure lots. Tomb Raider and Quake come to mind. While they "run" on a 486, they are quite […]
quake also came to my mind but it would run with 8mb ram minimal, and i did run it on a 486, so it doesn't count as "pentium required".
even quake2 was rumored to run on 386+387 rigs with 16 or 24mb ram, although i have never seen for myself. i only ran it on the same 486.
Reply 8 of 17, by leileilol
MDK really demanded a Pentium. It'll refuse to run if you fail the speed check at the start.
FUCK "AI"
Reply 9 of 17, by shock__
I always considered Carmageddon to be quite demanding.
Also Screamer 2 in software mode ... never ran at a "full" framerate with up to 700MHz.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 10 of 17, by F2bnp
Won't it run on a fast 486 with -486willbeslow ? If so, how much slower than say a Pentium 60 or 75 would it be?
Reply 11 of 17, by devius
carlostex wrote:
Grand Prix 2
I remember playing that on my 486 DX2-66. In my memory it ran ok, but 15FPS was acceptable back then, so I don't trust my memory that much in this regard 😀
Reply 12 of 17, by bristlehog
Pyl?
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 13 of 17, by Darkman
Quake , Tomb Raider, any build engine game, will all benefit alot from a Pentium with 16-32MB of RAM. Warcraft II will run on a 486 but really would benefit from something better too.
I also remember Wing Commander III recommending a Pentium 60 for SVGA mode, and even on a Pentium 133 it still has some minor slowdown at times (particularly when very close to a large ship)
Reply 14 of 17, by carlostex
devius wrote:
carlostex wrote:
Grand Prix 2
I think the point is running games with everything maxed out. Try SVGA with all details and frame rate at 25.6 and even a Pentium 233MMX will crawl at times. Specially at Monaco.
Reply 15 of 17, by smeezekitty
I hate software that tries to be smart and takes the option away from the user.
Reply 16 of 17, by soviet conscript
From what I've read, The Elder Scrolls: Battlespire is supposed to be very demanding.
Reply 17 of 17, by leileilol
On topic of BUILD games, they don't really demand a Pentium. The engine is entirely integer, one could say they demand a Cyrix or K5 😀
FUCK "AI"
