Yes, DOSBox does not work that way.
lee292 wrote:BTW, Scrabble runs quite nicely on my Windows 8.1 laptop.
Is your laptop running the 64-bit version of Windows 8.1, or the 32-bit version? (The System control panel will tell you.) Because 64-bit versions of Windows generally can't run any software that would run under Windows 3.1.
I got Windows to recognize the CD drive, but when I tell the only executable file, GHScrabbleInstall.exe, on the disk to run, the screen blinks once and then nothing happens.
If you start up DOSBox and try to run that file without starting Windows 3.1 (that is, by executing GHSCRA~1.EXE), what happens?
If it says "This program requires Microsoft Windows", then there might still be some hope. If it says "This program cannot be run in DOS mode", then it is a 32-bit program and either the disc label is lying, or there's another installer somewhere on the disc.
Did this game come with any documentation with instructions as to how to install it in Windows 3.1? Perhaps there is a readme.txt in the root directory?
