First post, by Guest
Okay I'm just not getting it. To play a certain game (Ultima 7) I have been trying to make the changes to the conf file i was told to make but I cant figure out how to get them to take affect. I decided to run a little test to see if the conf file i edited was even being used so I added a simple mount command to the end in the autoexec section to see if THOSE changes would take affect and sure enough they didnt. I have tried a hundred different ways to tell dosbox to use a specific configfile (as recommended in the readme) and it keeps telling me it doesnt recognize the commands. In short, I have no freaking idea if I am even using the syntax correctly but what I have been trying looks a lot like: "dosbox -conf configfile" as I am interpreting the readme to instruct. Sorry to be such a noob but can someone point me in the right direction?
