First post, by Waxxxz018
- Member
Whats up!
I just found a old copy of Heretic on 3 1/2 floppy & my drive does not want to read it, it just wants to be a bastard π and try to re-format my discs! π³ π
I have Nerves of Steel also (Whup-de-do, its okay I guess, coulda been way better though... π ) and it's made off the same format I think, IBM & Soundblaster & I can read that so.... Heres my specs. incase someone knows whats up.
I tried to see if DosBox would read it, but had no success. Still trying with VDMSounds, but the reason you see this post in DOS is because there might be a different way YOU know that don't require either. π
Thanks!
π΅ Waxxxz018 π΅
---"Nothings Impossible!!! It Can Be Done!!! It's Just A Damn PC!!! Show It Who's Boss Man!!!"---
