First post, by Chaniyth
So one of my multisync monitors has decided to go a bit wonky on me.
At random times it'll seems to lose "sync" [best way I know how to explain it] on the horizontal and cause severe interlacing and ghosting, I thought maybe it was the cable but I tried another cable and it still does it. If I turn the monitor off for a few seconds and back on the issue is cleared up but it comes back eventually. What is causing this, whats the proper term and most importantly is this issue fixable?
It's a Samsung SyncMaster 750p monitor, i'd love to get this working right because the image quality on it is amazing when it's working properly. I've attached some images of the issue.
The attachment 20150402_131106.jpg is no longer available
The attachment 20150402_131025.jpg is no longer available
The attachment 20150402_131019.jpg is no longer available
Thanks in advance. 😎
All the world will be your enemy, Prince with a Thousand Enemies, and when they catch you, they will kill you... but first they must catch you. 😁
Reply 1 of 1, by shock__
As usual with monitors - don't try to fix something internally unless you know what you're doing - or left them unconnected for a considerable time (like 2 weeks).
Usual suspect would be a flunky capacitor - certainly fixable but requires some basic knowledge of electronics and some gear for testing (ESR Meter, unsoldering equipment).
Awesome signature btw.
Current Project: new GUS PnP compatible soundcard
[Z?]
