First post, by fofff11
I am tyring to run dark forces on Mac and it keeps telling me cannot locate CD. Is there a way to get this running.
Or does someone have a step by step tutorial to do this on a mac? Thanks
Have you tried this?
http://www.dosbox.com/wiki/GAMES:Star_Wars:_Dark_Forces
It looks like all you need to do is copy the CD.ID file to the game folder, then edit the DRIVE.CD file as they describe.
I'm not using a Mac anymore so I can't be more specific.
Yeah, that should work, but you need to understand the drive letter differences 😉
But first things first, did you mount your CD and it still complained or did you not?
I believe I did yes. As far as editing the file, I have no idea or experience with how to do that. So again is there a detailed step by step for a mac on this?
What were your mount commands both for installing and playing?
mount c>Users>games>Darkforces ??
And you didn't mount the CD, too?
wrote:mount c>Users>games>Darkforces ??
I don't recognize that syntax with the ">'s"
The line I used to mount my "C" in DOSBox was:
mount c /Users/username/Documents/DOSgames/C -freesize 999
Or to use the "~" instead of the full path it would be
mount c ~/Documents/DOSGames/C -freesize 999
I created a folder named "C" to be my DOSBox C because I found it less confusing.
The folder you're using as your DOSBox C will probably be different.
To mount a CD I'd type something like this at the DOSBox prompt:
mount d /Volumes/name-of-the-CD -t cdrom
or if there were spaces in the name of the CD, I'd add the quotes:
mount d "/Volumes/name-of-the-CD" -t cdrom
I used this as a reference when setting things up
http://www.dosbox.com/wiki/MOUNT#Mac_OSX
fofff1, if you ever show up again, if you do proper mountings it should work fine.
Use some folder to mount as c (for example "mount c ~/games"), mount the CD-ROM as d (in the case of my DF version the CD label is GAME104, so the correct mounting is "mount d /volumes/GAME104 -t cdrom") and then install the game and play it.
KEEP THESE MOUNT COMMANDS EACH TIME YOU WANT TO PLAY THE GAME!
wrote:fofff1, if you ever show up again, if you do proper mountings it should work fine.
Thanks Im not entirely sure of the process. I Have a newer MAC. So the volumes/ or many of the c/ names on the forum don't apply - I have Doxbox. The game (dark forces) downloaded to a folder with all files.
Is someone able to walk through this step-by-step? Im willing to pay for help with this as well.. Thanks
1. What I wrote DOES apply, these things didn't change on a mac ever since OS X 10.1
2. We don't support illegal downloads - you don't have the CD, no wonder it asks for it. Poor you. Thread locked
This game WAS purchased from steam powered. Thanks
Also, we are talking about an extremely rare 1990s star wars game. You cannot even purchase it online, and the digital download is.......$5 --- so lets use some common sense here and be reasonable -- and again PM me if you can help get this running or can help. $$$
wrote:we are talking about an extremely rare 1990s star wars game
Dark Forces doesn't qualify for any rarity.
Debian's fucked
Problems with Dosbox need to go to the Dosbox Forum. Problems with the moderating of a mod -> contact the mod per pm, instead of writing a totally unrelated post that doesn't show what's it about.
I'll merge this and reopen the original topic.
As Leileilol wrote, Dark Forces is FAR from rare. Look at ebay and amazon, there are a lot of original copies to be found.
unlocked and edited the topic *slightly(?)*
The seconds post in this thread seems to be the relevant here. Edit Drive.ID with Textedit -> change the Letter in there to C.
OR you need someone to tell apart how the Steam version is configured and make that work...
And please, next time, give us all the information you can give. We told you repeatedly to use the CD, that could have been the first hint for you to mention that you got it off Steam.
