First post, by maxtrix
I'm just finished to build my '99 Rig machine. I have all set up but I can't find an audigy 2 driver for it, I'm only found windows xp / 2000 drivers, but nothing more.
Do you know how i can install this card?
Reply 2 of 5, by falloutboy
AFAIK Win98 drivers are only on the Audigy2 driver CD, if you don't have one get it from vogonsdrivers.com
Reply 3 of 5, by maxtrix
I have the audigy 2 cd but only have the xp and win2k drivers 🙁
obobskivich wrote:
I downloaded that but have mistaken the description, the file shows and error that is only for windows 2000 and up.
I think i will buy a SB Live! 5.1, because the audigy 2 is too modern for my rig.
Reply 4 of 5, by chinny22
I have the later ZS which installed fine in 98 so am surprised your having trouble with an earlier card. I got it cause it was the last card to support Win98. (I think Audigy 4 does as well but they are rarer and cost more for little benefit)
As fallout boy mentioned giving the vogonsdrivers cd a try is worth a shot http://www.vogonsdrivers.com/getfile.php?file … =544&menustate=
Although SB Live! 5.1 are cheep plentiful so an easy fix but you will loose EAX3 if that matters
Reply 5 of 5, by maxtrix
Forget all about I said it.
The CD in vogons is much more complete that the I have.
The Vogons Audigy CD have the win 98 drivers!!!
Thanks!!
