First post, by Barc
Hello there,
I'm currently using a PC which is running Windows 2000 and a TurtleBeach Santa Cruz as my soundcard, which I happen to have a problem with while running older games.
I was wondering if there's any users that manages to have Turtlebeach Santa Cruz working with older DOS games?
And I've read up regarding the DOS box but just wondering, how slow would it actually be when running the application with a DOS box on a PC with older Pentium 3 processors?
Thank you for your time. 😀
Reply 1 of 3, by Reckless
It all depends on what exact CPU speed you have and what game you're trying to run. Myself, I have a P3-1Ghz which is good enough to play point and click adventures, etc. Most action games are pointless unless the frameskip is high and then you're skipping animation which you're more likely to notice in that type of game!
Reply 2 of 3, by Xian97
I remember a friend had one of these and it worked ok, but in Windows 98's DOS environment. From looking at the FAQ for the Santa Cruz, it appears that the Soundblaster compatibility in DOS does not work with Win 2000/XP.
Q: I have the Turtle Beach Santa Cruz in Win XP, and I cannot get it to play
sound on games that use Sound Blaster. I read the help section that said
I need to use the Legacy DOS Game Device, however I do not have the option of using this device on my computer. I tried to reinstall the software but
I was not able to find a way to install the Legacy DOS Game Device. Could
you give me a detailed procedure to get this option onto my computer?
A: That option is only available in Windows 98. You must use a VxD Driver
in order to have Legacy DOS support. So, XP, 2000, ME will NOT have this
option.
