First post, by Cobra!
- Member
Okay, I finally got around to trying out Myst Masterpeice Edition... only to find out that it doesn't install...
When I click on the install button, nothing happens, so I tried going into the CD directory and tried to run it manually, that didn't work either... Running as an admin and trying compatibility settings didn't help either...
I tried install Quicktime, nothing, and when I look up the issue online, I only got results for the GOG and Steam versions, which installed just fine apparently, but never ran, whereas I have the retail CD version, which I can't even get to install...
What do I do?
