Reply 460 of 3179, by dogchainx
- Member
wrote:Still a moderately "nice to have" feature for folks who like their hardware unmodified - sure you could design a small ISA plugin board or hack another random ISA card to supply the voltage along its' usual functions, but that would either take up a whole slot or look "hack-ish". I've upscaled the normal -5V generator circuit for now (by means of power output and physically), with a jumper allowing the -5V to remain either local or be fed back to the mainboard along supplying the -5V to the amp on the card - also fills up a bit of unused space in the analog section (right part of the mainboard) so it looks less empty and less like the reference board 😀
All is good ... just got partially annoyed when I first tried to add the circuit, expecting it to be a lot smaller than how it turned out to be.
Kudos! Awesome work. Even though I'll probably never use the -5v line, its still nice to have "just in case". It'll make the card be highly-useful for multiple setups. Though an addon daughterboard would have worked, this is great work!
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
