First post, by hellzakk
Hi all, i've found this board but i see that's missing 2 component in the top left corner...
  • HOUSTON TECH HT12888A
    HOUSTON TECH HT12888B
it's relatec with the rtc...
i think that i have select the correct jumper settings for a P55C 166 MHz but it won't post and dont send any beep error code... any help?
Reply 1 of 1, by alexanrs
I have that exact same board. I don't think it can post without the HT12888A, since, not only it is the RTC, but it also stores the CMOS setup settings.
