First post, by maxtrix
- Newbie
Hi
I have an Audigy 2 card, this card works well in windows 98 SE, but I'm having problems to use it in DOS. I installed the SB16 emulation and the audigy 2 patch to use it in DOS.
When the system starts, it says it initialized completed. but there is no sound in DOS applications and running DOS apps to detect sound doesn't work
and if you go to DOS mode in windows, and try to run SBEGO.exe or any application to detect sound, the PC restarts itself.
here is how the AUTOEXEC.BAT runs:
And here it is the AUTOEXEC.BAT file:
mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi) mode con codepage select=850 keyb la,,C:\WINDOWS\COMMAND\keyboard.s […]
keyb la,,C:\WINDOWS\COMMAND\keyboard.sysSET CTSYN=C:\WINDOWS
SET BLASTER= A220 I7 D1 H5 P330
C:\ARCHIV~1\CREATIVE\DOSDRV\SBEINIT.COM
C:\dosdrv\Audigy12.exe
Here is the Config.sys file:
DEVICE=C:\WINDOWS\HIMEM.SYS DEVICE=C:\WINDOWS\EMM386.EXE device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1) Country=052,850,C:\W […]
Country=052,850,C:\WINDOWS\COMMAND\country.sys
SBESET -A220 -I5 -D1 -H5 -P330 -j0 -d1 -w0 -c
One thing I noticed is that the SB16 Emulation drivers always appears with an exclamation mark. Previously I had an IRQ problem with this but I recently solved forcing the Audigy card to the irq 7 (Assigning via BIOS the PCI slot), allowing the SB16 to take the irq 5.
(Windows is in Spanish, but is the same)
If you go to the device administrator, and check the resources of the SB16 and clic Accept, the exclamation mark dissapears but the system becomes unstable. Shows there is a driver called MMDEVLDR.VXD connot be loaded (Code 2)
What can I do to fix it?
