C&C Red Alert
First post, by Juggler
Hi!
I have finally installed C&C RA but when I start it, screen turns black and nothing happens. CDROM is properly mounted.
CPU: Athlon, 1 GHz
OS: Win XP Pro
What can I do?
Juggler
Reply 1 of 6, by THE_WUQKED
First of: DOS or Windows version?
If windows version: Have you tried comp modes yet and setting res to 640x400 (or was it 640x480?) with the red-alert config tool? I even had to do so in Win Me for the windows version, otherwise black screen as well.
If it's the dos version: Sorry, can't help you there 🙁
Reply 2 of 6, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
This is DOSBOX only forum. Discussions of Windows version belong elsewhere.
The same applies for any problems with running the game natively (without DOSBOX).
Mirek
Reply 3 of 6, by Juggler
Red Alert offers both a Win95 Setup and a DOS Setup. The Windows Setup failed (yes, I have tried comp mode), so I used DOSBox 0.61 to install it to C:\Games\Dosgames\CC. No Problem so far. In DOSBox, I mount my CDROM drive with 'mount e e:\ -t cdrom' and my HD with 'mount c c:\' When I try to execute ra.exe in \games\dosgames\cc, that DOS/4GW stuff appears and the screen turns black after a few seconds.
What is wrong ? 😕
Juggler
Reply 4 of 6, by mirekluza
DOSBox Moderator
Try adding -ioctl when mounting CD. IOCTL has better compatibility than standard SDL mounting.
I do not have the game, so I do not know whether this helps.or not
Mirek
Reply 6 of 6, by THE_WUQKED
Although this is the dosbox-thread, I still think that might help you (if no one else knows a way how to get it working under dosbox):
I had the exact same problem when trying to install the windows version (and with comp mode) under xp, and I found two helpfull tips:
1. install it on a 9x pc and copy the files to your xp machine, that normally works
2. you can try out the Red Alert Installer available on the net - it deactivates lan-game, though. I won't link it here, cause thes only side I know where to get it also offers warez. 🙁 The installer itself is legal, though (it just fixes the nstall prob, you still need the cds). So you'd have to search for it by yourself.
