problem playing WC1
First post, by permidion
hello,
i tried playing wing commander 1 ( the Kilrathi Saga remastered version) on win2k but without success.
whats especially unnerving is the game launch fine (fullscreen) and i can watch the whole intro animation with sound and gfx. Then at the end of the intro, i see the menu "Start Vega Campaign" for a second then game crash and quit.
i tried using solvbe but i must be a complet idiot because i didnt understand how to make it work with wc1, so maybe someone could explain with simple words that would be nice
tia
my config is as follow:
win2k sp4, 600MHz, 384 Ram, radeon 9200, inboard sound card
Reply 1 of 3, by Snover
Wing Commander is a notoriously bad series to try to get working. Do a search on the forum, you might find some information. (It's all such a tattered mess at the moment, I apologize; it's all been my fault.)
Yes, it’s my fault.
Reply 2 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
wing commander 1 is playable in DOSBox when you start the game like this :
loadfix wc
Water flows down the stream
Reply 3 of 3, by permidion
thanks for the advices.
i looked for other messages but most only refer to WC2 and none have the problem i have.
Is there really no other way than to use DosBox? I will try that anyway
