Asd
First post, by frisky dingo
Asd
Reply 1 of 28, by GeorgeMan
What do you plan on putting on the ISA slots?
Because that's the advantage of this mono against ordinary ones.
Core i7-13700 | 32G DDR4 | Biostar B760M | Nvidia RTX 3060 | 32" AOC 75Hz IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 2 of 28, by frisky dingo
Asd
Reply 3 of 28, by GeorgeMan
There are a lot of 430tx ATX motherboards with 4 isa slots and 4 PCI slots, where you could put a 100mbps ethernet card, 2x voodoo2 in sli and a matrox or nvidia tnt2 pci and still be able to use 3 isa sound cards.
Does the industrial mobo provide overclocking (multi change, fsb at 83MHz and voltage adjustments)?
You could always use a regular, new, super-fast SSD with an ultra-cheap sata->ide converter (dos compatible option), or even a PCI --> Sata controller in Windows 98.
Ok, it can and will be fun, it is extraordinary, but apart from that I don't think it's gonna provide something useful to you. 😉
Keep in mind that an ISA vga will GREATLY degrade performance.
Reply 4 of 28, by j^aws
That's a nice looking board - I have a similar one with an identical layout, although it needs to be recapped. Not sure yet if I'll use it in one of my final builds, but this is what I had in mind for it:
1) PCI 1: Since you can disable onboard VGA (which is a nice S3 chipset), choose another PCI VGA card to partner it and switch with - a Voodoo/ ATI/ NV/ TSENG variant.
2) Remaining 6x ISA slots:
ISA 1: See if you can find a slow ISA VGA card you can switch with:
486 Mobos: Can you install multiple VGA cards - like AGP/ PCI switching?
ISA 2: MPU-401
ISA 3: GUS
ISA 4: Sound blaster
ISA 5: Game blaster
ISA 6: Reelmagic MPEG card
Enjoy!
Reply 5 of 28, by AlphaDangerDen
This will be an interesting build.
Reply 6 of 28, by frisky dingo
Asd
Reply 7 of 28, by calvin
The Virge might have wimpy 3D, but it's a solid S3 2D core as far as I remember.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
Reply 8 of 28, by frisky dingo
Asd
Reply 9 of 28, by idspispopd
A Virge/DX (375) is not as weak as you think. After all, S3 have been making graphics chips for several years when they designed that chip. The video modes will pretty much be restricted by the 2MB RAM.
You should be able to get 800x600@24bit (1024x768 needs 4MB), 1024x768@16bit (1280x1024 needs 4MB) and 1600x1200@8bit (which is probably to blurry anyway). Heck, even image with the specs you linked to mentions 1024x768@16bpp.
Mach32 was introduced in 1992 while Virge/DX was introduced in 1996. S3 wouldn't have been successful for so long without descent resolutions and colour depth.
Reply 10 of 28, by kixs
frisky dingo wrote:
That's what I'm thinking, but iirc it has res limits, something like a max of 256 colors @ 1024x768 or something. And a max of 16 but color overall where as my Mach32 can do 24bit color. I will have to wait and see what it can do. That all aside I picked out a cpu, a 200mhz mmx pentium. I also found a old U1 copper cooler master heatsink and a fan that should work. Now just to find the mounting bracket, were did I put that? 😕
Put that ISA ATI card in P-233MMX system and you'll have it behave like a low end 486. If that is your purpose, then go ahead 😉 24-bit color on ISA bus is very slow and it simply can't compare to S3 Virge PCI.
Reply 11 of 28, by idspispopd
MACH32 PCI cards do exist. From what pictures I could find those were made at least in 1993.
Reply 12 of 28, by frisky dingo
Asd
Reply 13 of 28, by frisky dingo
Asd
Reply 14 of 28, by frisky dingo
Asd
Reply 15 of 28, by frisky dingo
Asd
Reply 16 of 28, by AlphaDangerDen
frisky dingo wrote:
It's coming along nicely. I'm still working on it so it will look much better when done. I also routed the vga output directly to the voodoo 2
Looking very nice! Can't wait to see more pics.
Reply 17 of 28, by Nahkri
Isn't a voodoo 2 sli, overkill for a pentium 200mmx ?from what I been reading on vogons, u need a much faster proc to benefit from the sli.
Reply 18 of 28, by frisky dingo
Asd
Reply 19 of 28, by Nahkri
frisky dingo wrote:
I'm betting a single voodoo 2 would be best.
Yeah i think that too,even if u have the ability to play games at 1024x768 with the SLI,not sire if the cpu has the power for that.
