First post, by TandySensation
Couldn't find any old reviews comparing both chips at the same speed(except for the 686 comparison on Vogons normalized to 133) All the reviews at Toms, Anand, etc, were compares at different speeds. The first P2 and the last P-MMX were the same clock speed, 233, I was wondering how much of a difference there would be.
So I setup a Pentium-MMX and a Pentium 2 both at 233MHz expecting them to be similar with a the edge to the P2 because of the faster cache(116 vs 66) but the P2 was so much faster according to the synthetic benchmarks. I can run the Pentium MMX at 250 with a 100FSB and it still lags behind.
Both systems used the same Geforce2MX and 256MB memory. A Via MP3 board(Fic-503+ 1MB L2 cache) for one and a 440BX(Intel Seattle board) for the P2. VIA chipset had memory timings set to the fastest with CL2, there are no tweak settings on the Intel board.
The P2 demolished the P55c
Sandra 2001: 3dMark:
CPU Multimedia Memory 3dmark01 3dmark99 CPU 3dmark99 3d
P55C 455/266 479/119 79/119 356 1621 1230
PII 625/309 885/331 162/193 687 8718 6912
The memory improvement must be due to the 440BX chipset which wasn't around with the P2 first launched but I'm not sure why the multimedia and gaming scores are so much higher. Both have MMX and a 32K L1 cache, was the P2 FPU improved a lot? I used a p2 350 with a 66fsb forcing it to 233 for the test. Maybe there was some improvement in the Deschutes core over the Klamath.
Figured I'd throw this out there for anyone interested and to listen to your thoughts.
