Strange POST
First post, by FE|)OR
Greetings, folks! I've got SiS 496/497 486 PCI Motherboard with AWARD BIOS. Well, in general it operates fine, but when I turn it on, it beeps *problem with video card* then shows vga bios, counts memory, beeps good post and boots OS. The video card is PCI S3Virge/DX. The most interesting thing is that it DOES NOT behave so being started out of case. Any suggestions?
Reply 2 of 6, by Matth79
Either you have a misplace metal mount shorting something, or maybe there is a hairline crack in the board which is being stressed
Reply 3 of 6, by FE|)OR
Beegle wrote:
May be a dumb question, but are you using metal or plastic risers between the board and the case?
I am using brass risers. Does it affect somehow?
Well... If it has a crack, there should be some other consequences than such a strange POST? Maybe I should try to load it as much as possible until it shows some other problems 😕 😕 😕
Reply 4 of 6, by FE|)OR
Guys, I've just discovered a very interesting phenomena! All that time i plugged that mobo to my philips 170X5 LCD and it did *strange post*. If i start it without display connected, it does *strange post* too. But if I plug it to my philips 105s crt, the POST IS FINE! I tried three other S3 in all PCI slots with the same behavior! Looks like that those S3 kinda dislike modern displays...Never saw anything like that...
Reply 5 of 6, by smeezekitty
Make sure you plug the monitor and the computer into the same grounded outlet
Reply 6 of 6, by FE|)OR
They are surely plugged to the same outlet 😀
